Through hole plating
player80
Full Member level 2
Full Member level 2
I went through some forum posts already, eg.
however I have also found some other sources on the internet, basically mentioning that they mixed waterproof colour with graphite for activating the area which should be plated.
I even think about just injecting graphite + waterproof colour with a needle into the small vias (I don't have so many in the breakout boards) and starting the plating process (however I'm at the beginning with learning about that process... and not sure if that will work)
Does anyone have some further experience with electro-plating in 2021?
I'm aware about the regular methods, put a wire through the hole and solder it or press some inserts into it (I have done that before already)
I'm milling some breakout boards and would like to have some proper holes through it.
