Los Frijoles
Full Member level 1
![Full Member level 1](/styles/images/ranks/elevel1.gif)
- Joined
- Oct 5, 2006
- Messages
- 98
- Helped
- 9
- Reputation
- 18
- Reaction score
- 5
- Trophy points
- 1,288
- Location
- Provo, Utah, United States
- Activity points
- 2,252
board issues surface mount through hole
I have two possible versions I have been designing for some time now. Since it is looking like I am going to be home long enough to finish it I guess I should get it fabricated. However, one thing needs to be decided before I order it and that is whether or not I should use a Through-Hole or Surface Mount crystal.
Originally I was going to just use a through hole crystal, but after having a friend of mine look over the board as another set of eyes he pointed out that my crystal traces were over 3in long and had several vias in them. So, we identified a spot where a surface mount crystal could go with no vias and 0.5" traces. The criteria for fitting in this space was that the crystal had to be no more than 7mm long, 3mm wide, and 1.5mm tall. The obvious problem here is that nothing really fit in that space except for a crystal made by Abracon that is 3.2x2.5x0.7mm. Now the problem is size: is the crystal too small?
My resources: 0.015" solder, 1/32" spade tip (on a variable temperature soldering iron), solder wick, and a relatively steady hand (successfully soldered a .4mm pitch 64tqfp by hand without overheating it).
Things I don't have: A magnifier, reflow oven
Things I don't have but could get: Heat gun, solder paste
I don't have enough experience with this sort of thing to answer it myself and I really can't afford to buy two versions of this board. Is using a crystal this small really worth it?
If this were you would you go with the through hole crystal at the sacrifice of clock clarity or go with the surface mount crystal at the sacrifice of ease of assembly?
