ee484
Full Member level 3
gm/id
Hi, all.
I heard that there are folks who use gm/iD methology for analog design circuit (In contrary, Vov or Vdsat design method) - some paper discuss about this methodolgoy (i.e., JSSC 1995)
Are real designers using this methodolgy to design analog blocks?
I understand that you first have to make script to approximate the all the design parameters (i.e., W, gm, iD etc), then later you just tweak the designe a bit based on your parameters.
If real designers use gm/iD methodology, are they using for all analog blocks or just use for big blocks such as opamps?
I'll appreciate if you have examples....
Hi, all.
