smitchell
Junior Member level 2
Hi, Im working on a project where i want to monitor voltages and currents in a 3 phase distrobution system.
I need to measure the following voltages and currents on a Y connected supply.
Phase to Phase
Neutral to each phase
Neutral to Earth
Current on each phase
I have to convert the readings to digital then send them through ethernet, so i want to keep the number of measurements to a minimum.
Is there any reliable way to calculate any of these voltages at the software end if certain other voltages are known? for example, if the voltage between phase 1 and 3 could be calculated if the voltage between phase 1 and 2, and 2 and 3 was known?
I dont know much about 3 phase theory, so any help would be much appreciated.
I'd also love to here if anyone knows how to build a digital voltmeter type circuit that can handle up to 500V.
Thanks,
Sam
Phase to Phase
Neutral to Earth
Thanks,
Sam
