Three Phase Pump controller_AN 984a
vir_paksh@yahoo.co.in
Newbie level 6
Newbie level 6
I am working with three phase pump controller, with AN984a, dspic33fj12MC202, working very fine and delivering out put of 240AC phase to phase at 60Hz, Now I need to have 380AV or 415 AC phase to phase at 50Hz, and I am in need of support
What´s exactly the problem?
* Increasing the power V_Bus voltage? --> show your power stage
* decreasing the frequency? --> explained in the AN
Klaus
To achieve 400 VAC phase-to-phase output voltage, you also need 400 VAC input and a power stage designed for 560 V DC link.
hi
Thank you, Even though bus bar voltage is 450V DC, corresponding output voltage is 240V AC at 60 Hz, I need at least 350V AC as out put phase to phase, what shall I do either in code or in the hard were
I have checked even on 550V DC link but out put is 240V AC phase to phase, by varying the AN3 ratiometrically V & F changes max 240VAC at 60 Hz
I dont see the problem.
Why? How do you come to this conclusion?
--> Show what you have done so far and how you calculated the value.
Klaus
Obviously, the voltage limitation is a problem of your software. You need to understand how the modulation index is calculated therein.
