adhul
Newbie level 6
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 module adc_12b(clk,d_in,d_out,sclk,cs); input clk; //,reset; input d_in; output [11:0] d_out; output sclk,cs; reg cs; reg [11:0] temp; reg [1:0] state=2'b00, nxt_state; reg [4:0] count,count1; reg [11:0] dout; assign sclk=clk; parameter idle=2'b00, read=2'b01; // always@(posedge clk) // begin // if(reset) // state=idle; // else // state=nxt_state; // end always@(posedge clk) begin // if(reset) // count<=0; // else if(count>=5'd16) count<=0; else if(state==idle) begin count<=0; count<=count+1; end else count<=0; end always@(posedge clk) begin // if(reset) // count1<=0; // else if(count1>=5'd16) count1<=0; else if(state==read) count1<=count1+1; else count1<=0; end always @(negedge clk) begin case(state) idle:begin if (count==5'd16) begin nxt_state <= read; cs <= 1'd0; end else begin nxt_state <= idle; cs <= 1'd1; end end read:begin if(count1<=5'd16) begin temp[0] <= d_in; temp[1] <= temp[0]; temp[2] <= temp[1]; temp[3] <= temp[2]; temp[4] <= temp[3]; temp[5] <= temp[4]; temp[6] <= temp[5]; temp[7] <= temp[6]; temp[8] <= temp[7]; temp[9] <= temp[8]; temp[10] <= temp[9]; temp[11] <= temp[10]; nxt_state <= read; end else begin nxt_state <= idle; dout<=temp; end end endcase end assign d_out=dout; endmodule
the timing diagram is as below
