thickness of gate oxide
srp
Newbie level 6
Newbie level 6
what is the impact on the device performance as the thickness of gate oxide increases or decreases.
Thanks!
Gate Oxide Thick : VT Increases
Gate Oxide Thin : VT Decreases
Thickness increases -> Higher Vt , less static power consumption, slower cell
Thickness reduced -> lesser Vt , higher static power consumption, fast cell.
:D:D
    srp
Any material or documents discussing in details this ?
Please share.
The two important equations are:
If the gate oxide thickness is reduced, then the gate area capacitance willl rise (\[C_{ox} \hspace{4mm} = \hspace{4mm} \frac{\epsilon_{ox}}{t_{ox}}\]). If \[C_{ox}\] rises, then the two \[\frac{1}{C_{ox}}\] terms will fall.
The only problem is that one of the \[\frac{1}{C_{ox}}\] terms is positive, and one is negative, and I can't prove which is dominant.
Qf is the charge term due to surface defects.... So the second one is dominating in normal conditions..
