thermo electric cooler
grittinjames
Advanced Member level 1
bangalore india
thermoelectric_cooling
i want to built a proto type electric cooler with iron and copper as thermo couple
any body worked on it .pls give me some information
I think you mean a peltier cooler. Have a look here: h**p://en.wikipedia.org/wiki/Thermoelectric_cooling
Roscoe
link which u had given is not giving a clear data
Roscoe
Have a look at this link. Here you can read some basics about TC-cooling.
h**p://www.marlow.com/TechnicalInfo/technical_information.htm
The Marlow company ist one of the world's leader of TC-cooling
just ask any thing u want i can answer it electrical coolers are new topic in electronic u can use the new cooling elements that doesnt need any water or thing
I tried Peltier elements :
Peltier elements draw high currents (10 + amps) ; not very efficient
The power supply heat generation can be a problem
The one side generate heat ; up to 100 deg C ; you will need a heat exchanger and a fan.
You need to thermly insulate the cold part from the hot part.
Added after 38 seconds:
I used a commercial Peltier element ; using p and n-type elements
