gres
Full Member level 4
It’s a 4 channels driver / temperature controller + 7 channels driver for irda/Bluetooth device. Device is simple but with powerful abilities
Thermo blaster – means “temperature tamer” consist some novel solutions like :
1. possibility to connect at 1 bus combined Dallas sensors from DS series, that means that you can mix DS1820 DS18S20 or DS18B20
2. system automatically recognize and inform what device is plugged to bus.
3. each sensor works with full 12 bit resolution!! So parameters for each of them are always the same – doesn’t matter which one is used and in with place. Think about situation when one of the sensor is broken and you don’t have any to exchange – not a problem !
4. you can connect sensors to bus 1 wire at any way. You can choose: 3 wires, or in parasite mode via 2 wires (this option can be set in menu!)!
5. wide range temperature check – depends on sensors
5.a. – each temperature sensor consist so called temperature trend arrows. Interesting is that you can set trend in very wide range. If you wan’t to know that from day to day you have increase or decrease – maximum range is up to 24h! but you can also set lower up to 20 seconds!
6. device is full controlled by re3mote control RC5 or sony. Slot control is very fast thanks to placed them on colors teletext buttons and also on numeric buttons 1-4. thanks to that you will remember which colour is for which slot.
7. simple way to recognize sensor on bus!! Very useful in repairing. At menu you can browse sensors at bus. System display:
- sensor name
- part of sensor ROM number
- temperature on each sensor! ( if you touch sensor by finger you will se temperature increase
8. device consist 4 “slots” at display. For example you can set that measurement in slot 1 is always temperature of CO pot, slot2 boiler temperature, slot 3 outside temperature , slot 4 house temperature
9. each slot can be co figurate to display :
- passing over maximum temperature
- decreasing to minimum temperature
- information about temperature window status
To each slot you can plug relay.
More information at https://www.elektroda.pl/rtvforum/topic1430008.html
