thermistor interfacing
ahsanali
Newbie level 5
Newbie level 5
thermistor or lm35
in my project" THE BURGLAR AND FIRE FIRE ALARM"
I have to use micro controller( 89c51 ) which is must
bcz microcontroller is my subject in class.
and thus i have to interface LM35 thermistor/temp sensor.
So, i want to interface the LM35 and 89c51.
How is it possible?????????
My Project=To make a fire alarm using microcontroller such that
the user gives it a temprature value as a barrier ,and
the system should also sense the environmental temp.
and when the environmental temp exceedes that barrier
the alarm should be switched on.
this is the very first time for me to work with microcontroller
so i want to know that how the circuit will be made,its workig,
interfacing,diagram
I shall be very thank full to u all for this act of kindness
adc interface into micro without ref
hi
to interface the LM35 into the micro you need to use analog to digital converter
ADC which converts the voltage produced by LM35 into digital value that you can read by the micro controller
note that LM35 gives (10 mV) change for (1 °C ) change and it has leaner response
Added after 11 minutes:
I think this link will help you ..
temperature sensor circuit using thermistor
If you have to use this particular microcontroller then you will have to select an external ADC, however if you are not then I would choose a microcontroller with built-in ADC. This solution simplifies your circuit and also software part of your project is much, much easier.
8 bit may be not enough for precisely sensing temperature with LM35 temperature sensor (10mV versus 19.5mV at 8 bits). Something like 10-bit converter would be probably better option.
If you would like to be stack with 8051 core then go to Maxim-Dallas web site ( www.maxim-ic.com ) and select a microcontroller there, or you can try www.microchip.com for similar product, if you can use the PIC core ..
In both cases you will be offered free samples ..
thermistor to micro interface
since the mcu is 8051 u have to use a 8 bit adc. the step voltage of 8 bit adc is 5v/256 = 19.5mV .and lm35 changes 10mv/0c so use a reference of 2.56mV so that the step voltage of the adc is 10mV and thus for each degee variation there will be change in the adc.
for more details refer "the 8051 microcontrollers and embedded systems"- mazidi
interfacing thermistor
Hi
we can use an operational amplifier to make the sensor response greater
such as LM324 or LM741 by amplification factor of about ( 8 ) or ( 10 )
lm35 thermister
Baslan said:
Hi
i think there is no need for amplifiers here. lm35 is linear and gives 10mv per degree rise. just changing the Vref of ADC is enough
thermistor microcontroller
If u have a hance try to use pic microcontroller. I 've made with 16F877...
ADCON1 = %10000010' configure the port
Define ADC_BITS 10 ' ADC result is 10 bit
Define ADC_CLOCK 1 ' ADC clock source( foscillator/8 )
DEFINE ADC_SAMPLEUS 50 ' ADC sample time
DEG CON 223 ' for a degree sign
TEMPERATURE VAR WORD
AD_Rez VAR word ' result of the ADC is 16 bit
C VAR byte ' for adc conversion
The code above all the initial setups made for measuring with LM35
You can call your measuring routine using code below
GOSUB MEASURE_TEMP 'call the routine
LCDOUT $FE,$D4,dec2 AD_Rez,DEG,"C" 'display on the LCD
This is the routine to convert temperature..
MEASURE_TEMP:
ADCIN 0, AD_Rez '
AD_Rez = (AD_Rez */ 500)>>2 '
Return
I hope this will help u..
