FreshmanNewbie
Advanced Member level 1
I'd like to understand more about Thermal shutdown in an IC.
I have read that, if the IC junction temperature exceeds beyond a certain limit, the IC shuts down itself which is known as thermal shutdown.
But once the IC is shutdown, how does it recover back and start to work normally?
I'm using this - IC. Not much information is given on this regarding the IC's thermal shutdown. Just it is mentioned that this IC has this feature.
So what conditions should happen for this IC (also in general) to go into thermal shutdown?
- Do we need to do a power cycle to make the IC work ?
- Or once the junction temp reduces to a certain value, the IC will start working again?
