Winsu
Full Member level 3
Hi All,
I have a Schottky diode in a LED driver design and it is getting hot. I have already increased the number of them ( 3 at the moment ) and I can't put more diodes because of a lack of space.
The case temperature reaches 105°C at worst case conditions and the Maximum Tj of the diode is 125°C. The datasheet of the diode doesn't include thermal resistance between case and junction so I can't calculate the Tj temperature.
Can I say safely that the Tj is below Tj maximun because in still air conditions Tj is just a few degrees above Tc?.
Thanks,
Winsu.
Thanks,
Winsu.
