[SOLVED] Thermal fuse
pgr2002
Member level 5
Member level 5
Hyderabad, India
In a 1.8 litre electric cooker, what is the capacity of thermal fuse used. Whether 10a or 15a fuse is used. What is the temperature (100 degree celcius or higher) at which it will cut off. In a sense can 10a : 100 degree celcius be used. Can anyone describe what is the best one to be used.
The fuse has a marking...
Typically much higher cutting temperature, e.g. 150 -175 °C. But it depends of course on the position.
Thanks. The markings on the fuse is not clearly visible and it is blurred due to which I couldn’t get the ratings
