stoyanoff
Full Member level 4
If we have 2 capacitators - one (for example) 470m/400V and another 470M/250V. The max charge is the same but they have different max voltages. Lets say we work with 200VDC voltage. The both caps start charging. When we stop the power supply the caps are charged. So if we have a load after every capacitator, is there a chance the starting voltage of the cap with 400V max to be bigger than the 250V or the output voltage of both will be the same???
