the vhdl code for the video processing
aasif
Member level 2
Member level 2
hdl images
I want to write some Verilog/VHDL code for image processing. Writing simulator to verify the code is a difficult task. Can any image file (e.g. bmp, tiff etc) be the input of Verilog(/VHDL) source code, and after processing the image, the output image be stored as image file (In hardDisk)? So that by seeing the output image, the processing can be verified.
reading bmp files verilog
I'm using a PCMCIA card with a VirtexII FPGA inside for developing a H.264 CODEC. It's from Annapolis Micro Systems and it's the WILDCARD-II.
https://www.annapmicro.com
With that I can load a video in H.264 stored in the PC and play the video using the decoder inside the FPGA.
Maybe this card can solve your problem, but I don't know how to load an image file to a simulator and then save the result to an image file. I'm also seeking for this....
how to read image file in verilog
This is a sample Motion Estimation include testbench in Verilog. FYI
h**p://opencores.org/cvsweb.shtml/macroblock_motion_detection/
what is the vhdl code to read an image file input
write a PLI, or use systemc. many simulator now support simple co-simulation of systemc and hdl
bmp to vhdl
Can u post here any example that uses PLI?
I want to read and write image files with VHDL/Verilog source code, can this be done easily? If you have any example then plz post it.
read and display images using vhdl
there is one book on PLI
"The Verilog PLI Handbook", by Stuart Sutherland, published by Kluwer Academic
Publishers, copyright 1999.
i have not find the ebook version. but has example on this book.
if what you want is to just read/write binary files, you can use verilog2k syntax
mainstream simulation now support v2k now.
if your simulator do not support v2k, find the popular fileio PLI on the internet. it is also a good example on how to write PLI.
reading bmp file in verilog
You can try to use PPM (P3) format for generating pixel output in verilog simulation.
It's a pure text mode format which can be generated by verilog $fdisplay function calls.
I've use this format to generate image outputs in both LCD controller and JPEG deocder project, enjoy!!!
v2k fileio
Digital signal Proecessing with Field Programmable Gate Arrays
Springer
U.Meyer-Bases
verilog read image file
Dear king002:
I have this book:
Digital Signal Processing with FPGA by Meyer Baese
Do you need it?
reading of bmp image in verilog syntax
Modelsim provides very good integration with tcl/Tk you can use that for
displaying the images directly. For this you dont need any PLI stuff!
how to read bitmap image in verilog
How hard is it to display a bitmap image using Tcl/Tk? Can this be done in other simulator-environments (like Cadence's NC-Sim, which also uses Tcl/Tk), or only Modelsim?
I'm guessing the image-display would be a 'post-simulation' activity (after the Verilog-testbench $finish.) You would use Tcl/Tk to read the experimental output-file, then try to display it? Is that correct?
image simulation ppm bmp
I had write a module to read/write bmp by using verilog system task function.
This module can be instance in Testbench to get the pixel value of the bmp.
If you need, I can share it.
Regard,
Jarod
verilog vhdl motion estimation
According to arun_student's request,
Here is the verilog code to read/write bmp format in simulation.
It doesnt support all formats of BMP specification.
I only use it to read/write 24 bit bmp file.
If someone is interested in improving it, please send me a copy.
Sincerely,
Jarod
display bmp modelsim
any new news regarding the image load on fpga using vhdl .
what i get as
1] convert image file into bin or hex file using some c code or matlab
2] use io file handling for access
3] again for output use matlab or convert file[matrix file] into jpg , bmp
images on hdl
In my previous method I used perl model for converting real image but its was in ppm format
