It is an alternative and cheap heating e.g. in the workshop. Firstly, you will need burners that burn used motor oil. An old wood stove was used to make this construction, based on simple schemes and photos easy to find on the Internet. The whole device is really cheap, probably the most expensive element is a thick profile for the burner. A ventilator from Fiat 126p is ideal for this construction.
As you can see in the pictures, there are two welded tubes on the left side. There is a semicircle in the letter C in the wood stove, which was to be connected to the cooler, but it turned out that the stove is able to boil water and so the cooler had to be disconnected and was destroyed.
The furnace operates well and is quite silent.
Link to original thread (useful attachment) – Kolejny piec na olej przepracowany by MG
