BlackOps
Full Member level 5
- Joined
- Jan 1, 2005
- Messages
- 279
- Helped
- 14
- Reputation
- 28
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- AZERBAIJAN
- Activity points
- 2,496
i am readin about Unit step function, and driven rl/rc circuits, and have some problems with
some exercise, help me please.
here is first exercise: At t = 2, find the value of 2u(1-t) - 3u(t-1) - 4u(t+1)
as i know,the Unit step function has this form, Au(t - t0), after t0 the value of function is
A.
if t0 = 0, then function's value is A, always after 0 seconds.
if functions is Au(-t), then its value is A only on negative side of t axis.
so, first i am a little bit stuck ... how to interpret 2u(1 - t)??? in this case t0 = 1? or
-1?
here is second exercise where i need help: The voltage source 60 - 40u(t) is in series with a
10 ohm resistor, 50mH inductor. find inductor current and voltage at t equal to: a) 0- , b)
0+ , c) infinity, d) 3ms
well, -40u(t) says to me that, after 0 seconds this function's value is -40, so... 60 - 40 =
20v
so in the case of a) 0-, the time is before 0... at this perioud function is 0, then 60 - 0 =
60v
and the current is 60v/10 ohm = 6A this is correct answer... but in the answer they write
that voltage is 0v!! why?
here is answer to this exercise: a)6A, 0v b) 6A, 40v c) 2A, 0v d) 20A, 22v
could u help me with these exercises please, and explain... thanks
A.
-1?
20v
60v
