zizbear
Hello ,
When I use stb to analysis a multiloop circuit, for example-- a bandgap with the OpAmp topology. There will be at least two loops exist in the circuit, right?
When I use stb to test the loop gain for one of the loop (loop positive), in this testbench--do I need to break the other loop(loop negative) ?
The stb result(loop gain, loop phase-- plot) for loop positive is very different depending on whether i break the (loop negative) or not .
How to understand the different? Or the stb simulation plot is not the real sub_loop gain and phase?
In theory, do we need to ac break other sub_loops while checking one sub_loop?
I am real confused...
Thank you very much !!!
