chang830
Full Member level 5
The circuit I am designing need to have hgh drive capability. In layout, I put the driver transistors compact to inprove the matching charateristics. But I found the thermal intensity is high to 200W/cm^2 for the area of compact driver transistors.
I have the concern the heat will brings the reliabilty for my IC.
Any guideline on the restriction for the heat on chip?
Thanks
Thanks
