hi.when i connect LM35 to ATMEGA32 in proteus ,the lcd shows zero to me,im sure that my code is true,because when i use lm 50, the lcd shows me the number.also i have 3 errors from protuse which is shown in the picture.
.how can i fix it?
The model works, I have used it, I think that your problem is that you are using the wrong ground symbol, use the ground symbol used in hamidmoallemi post.
There maybe another LM35 symbol with a model, look and see as often different packages do not come with the model. If you do not have a model for the LM35 maybe it has been deleted, you could then try and reinstall Proteus or pinch a model from another version of Proteus, I can confirm that Proteus 7.11 has the model. What version of Proteus are you using?
