the platform:arm(with mmu)+mpeg2+linux,help
3walker
Newbie level 1
Newbie level 1
lsi2000 mpeg
i want to design the platfrom:cpu use arm(with mmu) or others,which can run linux, a mpeg2 chip thransit mpeg2 to tv . who can give me some advice? or there have production in existence so i can use it?
if i use xscale + saa7212 +fs450 ,can it work?
hi ... i have seen and excellent sateleite dvb receiver based on linux .. it is not arm but worth to see ;0) powerpc+mpeg2+linu look for dreambox
The dream box is a nice solution, but even although it is based on the IBM PowerPC it does all the MPEG/DEmux/SI and all stuff in hardware.
If you want to do it yourself entirley in software for free then many projects are around the web for this, but you will find hard time to get Linux + DVB running good, I have seen problems even on fast PC with these cheap demodulator cards sold at auction sites.
If you are looking to design a STB then most vendors support Linux on at least one platform such as IBM, STM, and I think Connexant, Zoran and Micronas too.
:R
:R
Galaxis & TopField 5000 Pvr is using Linux too architecture using EMMA2 (mips core)
I ever see LSI2000 already implement in linux too.
