Ace-X
Advanced Member level 2
arm7 contest
Free evaluation kit is available:
The Philips ARM Design Contest 2005 is your introduction to Philips’s powerful LPC2000 microcontroller family. These RISC MCUs are based on the high-performance 32-bit ARM7TDMI-S™ microprocessor, which features low-power consumption and 16-bit Thumb code for efficient and flexible designs. Other key features include a wide range of serial communications interfaces, on-chip 8/16/32-KB SRAM, 32-bit timers, single or dual 10-bit eight-channel ADCs, a 10-bit DAC, PWM channels, and 47 GPIO lines. These features coupled with a small footprint make the LPC2131/2132/2134/2136/2138 microcontrollers ideally suited for countless applications, such as access control, point of sale, communication gateways, voice recognition, industrial control, and medical systems.
The MCB213x-U Evaluation Kit features the Keil MCB2130 Evaluation Board populated with the new LPC2138. The MCB2130 evaluation board introduces you to the newest Philips LPC213x ARM7-based family and allows you to create and test working programs for this advanced architecture. Included on the evaluation board are two serial ports, eight LEDs, and a speaker. The evaluation board allows you to experiment with ARM applications and the Philips LPC2130 devices. An evaluation copy of the Keil ARM development tools is included in the MCB213x-U Evaluation Kit.
