the path of modelsim.ini
Well, then I suspect you should look harder. ;-) AFAIK when you do a default install of modelsim, you get a modelsim.ini with boring default content. Should be in the root dir of your modelsim install. And if you assume we are mindreaders, and mean to ask "where is the modelsim.ini generated by compxlib?" then you should read the compxlib log since it says where the output went.
