yanda
Junior Member level 1
Good day to all, am a little bit confused about the terminals or the output terminals for a both an astable, monostable, and bistable multivibrators.
in addition, i was learning something on the multivibrators and i tried to use an idea of the theory associated to the ON and OFF(SET or RESET) pulse duration (of elapse) and to use a multisim simulation software to test run it and see if actually the two states will b unstable but i didnt notice anything, so i quess my design was wrong or perhaps didnt know how to chose my required components and use the multisim software. i use the following component for both sides: transistors 2N2222A(2 transistors), 1.0k ohms resistors(4 resistors), two 3300 microfarads capacitors and i used +5V dc to run it- is this feasible?
also, i used a transistor's configuration and not 555 timer
perhaps somebody could giv a clue on how to design d multivibrators using both the 555timers and transistor configuration showing ol the details in term of input and output terminals and perhaps attached the circuit for me; also put me through on how to go about simulation it using MULTISIM simulation software
thanks in advance
thanks in advance
