That looks like C.
"outport" is not a standard C function.
You didn't tell us which compiler you are using. I'm guessing "outport" sends a byte to a port.
If those are correct guesses, then the ^ operator is bitwise exclusive-or, so the function outputs the value 0x0E to port 0x379.
