The Howland Current Pump with balanced-bridge resisters
engr_joni_ee
Advanced Member level 3
Hi, I have found this article that describes how to get current source with Op-Amp.
If I chose R1 = R2 = R3 = R4 = 3.3 K Ohm and input voltage Vi = 3.3 V then theoretically I will get 1 mA current across the connected load. How much precise this current source ? Would it worth if I use this 1 mA current to setup PT1000 temperature sensor application ?
You have to do an error analysis to answer your question.
- R accuracy
- OpAmp Vos, Aol, PSRR, Noise
- Temperature effects
Best way is to do this, followed by sensitivity analysis to focus
attention to biggest errors first.
https://www.ti.com/lit/ml/sprp524/sprp524.pdf (This focuses on filter, but same principles
apply to DC analysis).
Regards, Dana.
