You cannot buy a transistor with a beta of 100. You can buy a few hundred transistors and measure them all then you might find one.beta for BJT is 100
It is too simple:Simple relation Ic=hfe*Ib where Ib=(Vcc-0.7V)/Rb
Dear azimSir. How to find the hfe in bjt transistor using Multimeter? Help me....
A transistor usually has negative feedback applied so that it is biased correctly. Negative feedback can be a biasing resistor from the collector to the base or a series emitter resistor.
