The extraction problem of BJT transistor
Question
Member level 5
Member level 5
My design environment is TSMC 0.18UM MM/RF 1P6M SALICIDE 1.8V/3.3V PROCESS PDK (for Cadence) Revision 1.1a. There are some BJT transistors in the circuit. The cell name of BJT is ' vpnp3 ', the view name is ' spectre ' in my schematic. There is no layout pcell of BJT transistor in the PDK, so I make the layout design by myself.
When I run a extraction by the diva rule in the PDK, it will give me a warning massage ' Cannot match terminal counts for vpnp3 ivpcell tsmc18rf '. Because of this problem, I can not clean the LVS. If I use Hercules to run a extraction job, I can get the right BJT transistors. The runset file of Hercules is ' LVS_Hercules_0.18um_MM_1p6m.20a '.
How can I get the right extracted view by diva rule? If I can not get the extracted symbol, how to simulate the circuit?
Thank you.
For BJT devices each model correspond to fixed layout. Pcell cannot be used for layout development. Usually TSMC provide GDS file for each BJT model.
for BJT devices in tsmc CMOS process , foundry do provide fixed layout we can`t draw it on your own .you have to require the gds file from the foundry.
