The equation for converting from value of TMR1L in timer 1 into microseconds
NadaF
Newbie level 6
Newbie level 6
i need equation to convert value in TMR1L into microseconds on pic 16f877a using mikroc language plzzz anyone help me !!!! :(
my code using mikroc language:
i'm using pic 16f877a , timer1, internal clock
int Dis;
int Dur;
int T;
void main()
TRISB.B7=1; // i/p for pic
TRISB.B6=0; // o/p for pic
while (1)
if (PORTB.B6=1)
T1CON=0001001; // timer on
if (PORTB.B7=1)
T1CON=00000000; // timer off
T= TMR1L;
Dur=T/4/1; // lsa freq of osc. /4 / prescaler rate 1:1 -----> is that convert value into microseconds ?!
Dis=(Dur/29.1)/2;
If you had a 4MHz xtal, then the instruction cycle time is 1MHz which is 1uS.
The timer is incremented at the instruction cycle rate, so with a prescaler of 1:1, each count is 1uS.
Reactions: NadaF
    NadaF
