In my experience, two version very different beside same interface.
gabby's pronounce website is exact.
actually very important point is not allow PLI on PE, so can't run a full bus-fucntion simulation that similar h/w s/w co-verification.
and acutally very very late to do simulation, sometime get angry too late --;
But in http://www.model.com/products/prodcomp.asp
PE has supported
** Verilog Programming Language Interface
** i.e. PLI 1.0 (tf & acc functions), PLI 2.0 (vpi functions)
PE does NOT support
VHDL Foreign Language Interface (Modelsim FLI)
When I made progess project that crypto-module, I used both language (VerilogHDL, VHDL)
I did concurrently both language. so, I confused.
For test, I used Altera Excalibure. At time, I had used PE and SE modelsim.
There are "Full-bus function simulation" that Excalibure verification name.
Full-bus function simualtion some alike HW checking simulation with PLI, FLI. (Before I was only using PLI at Verilog-XL)
SE can run PLI and FLI, but PE can't run FLI.
sorry my wrong.
