negative feedback cause to unstability and use for oscillator biuld.(-)vijay_nag said:HI
WHAT IS DIFFERENCE BETWEEN POSITIVE FEEDBACK AND NEGATIVE FEEDBACK AND WHY WE NEGATIVE FEEDBACK IN OPAMP
mm_naghsh said:negative feedback cause to unstability and use for oscillator biuld.(-)vijay_nag said:HI
positive feedback is more usual and useing for amplifire.(+)
you can see lm741 datasheet and astable circiut .
Actually, Aβ is the loop gain. β is the feedback ratio. Not a big deal, but for someone trying to understand op amps, correct terminology is important.Miguel Gaspar said:...Vo/Vi(s)= A/(1+Aβ) ≈A/(Aβ) = 1/β
where β is the loop gain...
hello,tjr said:positive feedback for oscillations and negative feedback for stability
