The definition of the UWB power spectrum mask.
wccheng
Full Member level 5
Full Member level 5
uwb spectral mask
Dear all,
As I know that the FCC power spectrum mask of the UWB is around -41.6 dBm/MHz. However, this power level is measured directly from the PA output through the cable connection OR measured it from the transmitted antenna? Where could I find this material?
Thanks
wccheng
uwb spectrum mask
Well, I am just getting up to speed on UWB for a radar application. Apparently, you have to meet two things. The spectral mask at -41 dBm, AND part 15 emission limits (in uv/meter-which would cover the attached antenna gain).
https://www.freescale.com/webapp/sp...wmsg/08-09-04_1ST_FCC_CERT_FOR_UWB.htm&srch=1
Also, this is interesting:
https://www.fcc.gov/Bureaus/Engineering_Technology/News_Releases/2002/nret0203.ppt#2
But the exact measurement method appears to be contained in pages 60-80 of this document (which I have not read thru yet):
https://www.fcc.gov/Bureaus/Engineering_Technology/Orders/2002/fcc02048.pdf
