The correspondance of a coaxial line to a transmission line
arthury
Junior Member level 1
Re: The correspondance of a coaxial line to a transmission l
Hi everybody:
Just now I create a very simple coaxial line model in both CST and HFSS to study the correspondence of real waveguide to transmission line model. But the result seems confusing.
My coaxial line is a inner PEC cylinder pin with the radius of a=1mm, and an cylinder PEC shell with the inner radius b=3.83.
The material between the inner pin and out shell is vacumm.
the CST model is as follows
The calculated port line impedance is 80.694ohm, which is in accordance with the analytical result.
I set a port at one side of the coaxial and the other side as Perfect E boundary.
Now I assume this device model is equal to a piece of transmission line with characteristic impedance Z0=80.694, and the end load impedance is ZL=0 because of the pefect E boundary I set.
Since the port feeding transimission line is of the same line impedance with my model, then the total transmission line model I believe is as follows:
Then I believe the S11 at the port should be equal to the reflection coeffecient
Gamma(-L)=Gamma(0)*exp(-j2kL)=-exp(-j2kL), because
Gamma(0)=(0-Zc)/(0+Zc)=-1.
This means the magnitude of the S11 should always be 1 and only the phase of the Gamma changes with the length of the transmission line. This is a very basic model of short circuited transmission line.
Then in CST I set the length of the coaxial line to be 16mm and the frequency to be 40GHz. The analytical result of the Arg(S11) should be 82.953degree, while the simulation result of Arg(S11) is 71.18degree.
I tried many value of the length of the line and the phenomenon is that when the length is small, the simulation result of the Arg(S11) is close to the analytical result,and when the length of the coaxial line is longer, the difference becomes obvious.
So my problem is whethen my equavalence of the coaxial line to the transmission line is valid. and whether the PEC boundary at one end can be equal to a short circuit load ZL=0?
Added after 1 hours 1 minutes:
Just now I did a bunch of simulation in both CST and HFSS, and found that when the coaxial line length is becoming longer, the S11 value from CST and HFSS are becomming more and more different from the analytical result. (hope my analytical model assmuption is correct
Line Analytical
Length result CST result HFSS result
0.2mm 160.787 160.8 161
0.5mm 131.967 131.9 132
1.1mm 74.324 73.9 74.1
2mm -12.13 -13.59 -12.7
3mm -108.196 -110.4 -109
7mm -132 -137.6 -134
10mm -60.6 -68.01 -62.3
15mm 179.018 168 175
20mm 58.6912 43.96 55.7
30mm 178.037 155.9 174
50mm 56.782 19.71 47.4
and from the above figure it is also obvious that the HFSS result is more close to the analytical result than the CST result.
Hi arthury,
your mode setup and your thoughts a O.K. You observer something which is called mesh dispersion error. This error will go away if you increase the mesh density. I did run your 16 mm model at 40 GHz and plotted the phase agains passes of the adaptive mesh refinement (expert system based). As you can see, the simulation results converge to the theoretical results if the mesh density is increases. In HFSS you usually always run an adaptive mesh refinement in MWS you normally already get some reasonable results even with the basic mesh.
Keep in mind, the phase error is actually smaller then as you might think. The “true” phase of your mode is actually -1717 deg and not 83 deg. As you already mentioned in you theoretical considerations you have multiples of 360 deg which have to be subtracted to get to your 83 deg. Taking this into account, the “phase error” even with the basic mesh is about 1% in my model. When you run the adaptive mesh refinement, you should make sure that you either force more then two passes or that you decrease the target for the delta S. Otherwise the mesh adaptation will stop after 2 passes because the error is already small.
Happy new year.
F.
Oh, yes, your explanation really make sense. Actually the phase is a continous number. it is the problem of 360 substraction.
And actually although the value does not match very perfectly, the trend of the phase versus the length is the same as the theoretical result.
I really appreciate your patience
