The control of lamp 12vdc
saowaluck
Newbie level 6
Newbie level 6
I want to design circuit that control the lamp 12vdc which it have to more light.but transistor is C458 only.
You question is not clear. The 2SC458 is rated at 30V and 100 mA, so it could drive a lamp with that much voltage and current. Here is a data sheet:
high
it is also my problem too
if you found the answer please publish it
thank you
imxo, MOSFET + PWM use for 12 VDC lamp light control...
