tipu_sultan
Member level 1
Which is the best CAD software for electrical drawings (automation, PLC) ?
For professional drawings the AutoCAD is the best as it has built-in blocks and also compatible to PDF, Word and image files.
For PCB designing it is the best but its takes some time to be master on its command its measurement is precise without error.
Also we can import built-in design from the library.
But for real-time electrical simulation the Proteus is best as it works on accurate time. One should design its circuit in proteus before making hardware so can judge the output correct or incorrect.
But if you want to make your drawings in small scale use Multisim for electrical drawing and Express PCB for PCB designing as these tools are simple and easy to master on it.
