The 3.3v lithium battery, what is the lower limited voltage?
leonken
Full Member level 3
Full Member level 3
That means, when the battery is discharged, the minimum voltage that can not damage the battery
Thank you
Re: The 3.3v lithium battery, what is the lower limited volt
Most lithium batteries discharge to 2.3V per cell safely. Below that you will start to damage the battery. Check with the manufactures site for your particular lithium battery that you are using.
go to manufacture 's web .they must have this message.
