How will I know that the frequency is adjusted? What is the simple way to do that?The frequency is adjusted by a ferrite slug in the centre of the coil until it is exactly the same as the crystal.
The crystal grounded the base at 27MHz, so the transistor is configured as a common base amplifier?The transistor is configured as a common emitter amplifier.
I have calculated the reactance of that 82p cap and it was almost equal to 72 ohm. Is not a large value? Why not choose largest value of the capacitor so that it becomes less reactive?It has a resistor on the emitter for biasing purposes but the 82p across the 390R effectively takes the emitter to the negative rail as far as the signal is concerned.
Dear samy555
Hi
The crystal , grounded base at 27 MHZ , and feed back path provided with CE capacitor ( internally capacitor ) and tuned network at collector , provided another selector ( frequency selector) . with this consideration it will be alike with HF coolpitts oscillator .
BTW : hasn't this circuit , any input signal ( my mean is modulating signal ?)
Best Wishes
Goldsmith
That encouraged me to ask, thanksWhen you sensed that i can help you , feel free to ask me
What do you mean by "CE" ? did you mean Emitter cap or the internal cap between collector and emitter?The crystal , grounded base at 27 MHZ , and feed back path provided with CE capacitor ( internally capacitor ) and tuned network at collector
I did not understand that sentence.provided another selector ( frequency selector)
Circuit will amplify the thermal noise filtered by xtal with fundamental and harmonics and amplify signal to collector tuned fundamental with high gain where phase shift is 180deg with feedback from internal miller capacitance. (CE) THis appears to be series mode osc. Parallel mode might use Xtal in CE feedback path. eg >http://talkingelectronics.com/projects/27MHz%20Transmitters/imagesP2/TX-2Bcct.gif
Dear goldsmith, Nqw I'll go to read about crystal fromDear Samy
At first , about series and parallel resonant , see below , please :
http://en.wikipedia.org/wiki/Crystal_oscillator
And about feed back capacitor , yes , it seems ok for providing positive feed back ( don't forget , at CB amplifier the in put is emitter and out put is collector and we don't have any phase shift between input and out put )
And about name of this oscillator : as i said , it is alike coolpitts oscillator ( if you replace a capacitor with crystal , but i don't know the real meaning of this circuit when we have a crystal at base )
Best Wishes
Goldsmith
Dear GoldsmithDear samy
why headache ? electronics is sweeter than things that you can find in confectionery !!!
I look forward to discuss this with you, but before that, I have a good book in Electronics and I want to read more about oscillators, and then come back to you.Dear Samy
Hi again
We can analyze that circuit with mathematical equations , at first , for oscillations , we should create situation of oscillation and we should create :
1- a good negative resistance .
2- unstable poles
3- to keep oscillations we need Av* beta =1 ( beta is feed back network gain .)
but with these considerations ,design steps will be a bit complicated .
I hope that you give me the rules.How ever , i can give you some simple rules to design this oscillator ( to select the values of elements with your self ! )
If you want , i can say , simple rules of design .
Yes, I agree with you completely.And about articles and books : you won't find , all of your desired things ,in a book and an article ! you should read some books and articles .
Since gain is a ratio of collector to emitter impedance. Look at the effective capacitance ratio (C/E ) including Pi filter and you need is >1 loop gain @360deg to oscillate, one would have to do worst case tolerance analysis to see is variation in hFE will support this solution, but there may be a rule of thumb.
Did you mean that a 82p cap is largeso the circuit designer need to pi filter?A bigger emitter cap will drive more gain in osc. Too much and it becomes nonlinear, hence need for Pi Filter.
Reader's Digest version of XTAL Book https://en.wikipedia.org/wiki/Crystal_oscillator
Note that the cool thing about AT cut XTALs is the inductance of L1 in Henry's like a huge power transformer but the motional capacitance, C1 is < 0.1pF so it cannot transfer much energy, and can burn out but provides extremely high Q of 10K, which translates into an inexpensive 50 ppm crystal. ( 15 cents or less in volume)
Whereas inductors are much less accurate and more expensive and lower Q.
I have also used 5'X cut for VLF filters and SC cut for OCXO ultra-stable designs <1e-11
