.tgz file to PAD layout
1a2s3d4f
Member level 3
Member level 3
Hi everyone,
I would like to ask it is possible to open file that generated from CAMCAD like .tgz file to PAD layout. Can you guy please direct me to the instruction.
Please help.
Thanks
If I'm not mistaken, the .tgz file format is a compressed file. Maybe you should check first if you can extract the contents of this file and see what it has first? I'll take a guess it will be a collection of manufacturing files like gerber and nc drill, etc.
tgz is a file extension coming from the unix environment and indicates a "Tarred and GZipped" file. You can extract the contents of this file with winzip, winrar etc.
ODB++ is using this compression when you use a compressed ODB output file. Unzipping such a file will result in an ODB++ directory with readable files.
Thanks for confirming senilicus. I was fairly certain it was some sort of compressed file, kind of like gzip, but wasn't 100% sure.
