kvr71199
Newbie
Hello,
This question is related to tetramax tool (run_atpg)
1)after running "run_atpg"(command) :test_coverage is 100% and it gave 36 patterns
then I saved that patterns using the "report_patterns" command in file_1 then I wanted to write that patterns in STL format
2)I used Write_patterns command ,file is generated (file_2) but the patterns were different in both files
may I know the reason?
Thanks in adavnce
Thanks in adavnce
