Ahmed4444
Newbie level 6
HI
it's my first time to use IPM(6MBP15rh060) ,and i need to make 3 phase inverter .i use microcontroller to generate 6 pulses shifting by 60 degree , 6N136 optocoupler to interface MCU with IPM , 3 resistance Y connected as a load and VDC =200V . but it didn't work and not give the correct waveform of the output. View attachment REH983a.pdf
1- i use the same circuit as in example page 55 except for 3 resistance Y connected as a load is it any thing i miss?
2- how can i confirm that IPM not damaged? how can i do some test procedure fo IPM?
thanks in advance
thanks in advance
