sdowney717
Member level 1
In the rebuild of my 3000 watt inverter, I am testing these mosfet. I found 8 definite bad ones shorted or will not turn on.
How about those that display a lower voltage reading when they are turned on with my meter?
some display .3v and others display up to 1.1v
All the 'good' ones function as in they turn on and they turn off. Following the test procedure from here called 'simple test'.
But I was wondering if those that display lower readings are worse compared to those showing higher readings?
https://www.4qdtec.com/mostest.html
