rickyjar
Member level 2
User “stayout” made a very useful toy – a tester of electronic elements.
The project was being carried out on the basis of Link and **broken link removed**
Thanks to high quality elements, accurate and repeatable readings were obtained.
Construction time: 4h
Expenses: Atmega8, display, other
Everything is aptly described in the second link. One difference in construction is a 22Ω contrast resistor instead of a 1kΩ, which results from the display used.
The tester supports:
-Diodes (such as rectifying, double, LED ones)
-Transistors (such as bipolar, mosfet, jfet ones)
-TRIACs
-Thyristors
-Resistors
-Capacitors
Link to original thread - Tester elementów elektronicznych na Atmega8
