Testbench: variable clock
dd2001
Full Member level 4
Full Member level 4
How to write a variable clock generator?
always #cycle clk = ~clk;
want to cycle auto increse 10 every #500.
Any one guru can help?
Use several clock sources, then mux those clocks together and that mux controled by counter(s). Since its not synthesisable, you need NOT to worry about the glitchs, load....
Is this what you want ?
`define cycle_main 100
`define cycle_inc 500
`define inc 10
integer tinc;
initial begin
tinc = 0;
clk <= 0;
end
always begin
#(`cycle_main + tinc)
clk <= ~clk;
end
always begin
#(`cycle_inc)
tinc = tinc + `inc;
end
Well, karlheinz:
It is very close, I just want it functions like a VCO, if feedback 7-bit data changed, then frequency also follow.
Thnaks.
