Car_modifier
Newbie level 5
How do you test a circuit to see if it's latched or pulsed. Mainly Rear defrost on 04 Dodge Intrepid. I think I figured it out but would like someone to confirm...
Pulsed: when I press the button to activate the rear defrost it sends out a quick pulse to activate defrost relay (negative pulse into a positive system) this would cause the voltage to drop quickly and briefly from 12v +
Latched: When I press the button it sends out a steady negative current to drop the voltage from 12v + for a duration (10min) then turns off and voltage resumes to 12v+
Is this correct?
Is this correct?
