Test points in ML605 Vertex 6 Board
sriharsha.hs
Junior Member level 3
Hi folks,
I am using ML605 (Vertex 6) Evaluation kit. I want to test my design output in oscilloscope. So, I am not finding any test points in the board.
I went through the data sheet and getting started guide related to ML605. But I am not finding any info regrading the same.
Please, can you guys guide me.
Thank you.
Hi folks,
Thank you.
time has changed. you will need to put it to the FMC connector, or find a jumper connected to io pin , that is not used.
Hi aruipksni,
Thanks for the reply. I directed all my signal outputs to DIP switches present on ML605.
