Test of DC/DC Converters
chanchg
Junior Member level 3
Hello Everyone,
Can anyone let me know how to test a DC/DC converter when NO load is present?
Regards,
Chanchg
You can only test for the output being at the proper voltage. Try using resistors to draw different currents to test for static load regulation. You can switch them in and out with a power MSOFET to test for transient regulation.
it is easy in sim
but hard in tese
It is always good to precisely specify what IC/device do you have in mind, as different devices may behave in compltely different ways.
If you have unregulated-output dc/dc converters they will usually generate approximately 130% of nominal voltage without any load: for example small 5V dc/dc without load will have around 6.5V ..
Also, instead of changing linear loads (such as resistors) you can use for test non-linear load such as a light (bulb) rated for 60-80% on max load. This will test a dc/dc converter for inrush current as well as normal load ..
Isn't the control loop affected by NO-Load situation? Like in Current Mode control, minimum ripple is needed for Loop Stabilization..
Chanchg
Yes. Some converters require a minimum load to work. Many years ago there was on the market one that would self destruct with no load.
