Coconuttopdrop
Newbie level 3
Hi.
I'm repairing a AMEK mixing board but i dont have an extensor to power the channel's that i'm fixing.
What i'm doing is comparing some readings on a good channel with the bad channel.
The EQ section of the board as 4 TL074CN IC's, and some are busted, but i dont have a way to see wich are ok and wich are busted because i cant power the circuit.
So i need to do some kind of circuit to test the IC's.
The TL074 brochure has a audio amp circuit (fig.25) wich i can try to replicate, but i have some questions.
Using a DC power supply, should i feed 12V to CC+ and hook up the ground to CC- and feed 6V to ground?
Thnks
Thnks
