Test bit of byte in QBasic 4.5
Sputnik
Full Member level 3
Full Member level 3
South Africa
I've been trying to accomplish this for a few days, in fact, I don't even know why I bother asking for help cause I just won't finish the project anyway, but maybe this one will work out.
I need to test a bit of a byte in QBasic so that I may know whether or not to add a specific value or not (to set the bit) so that I don't get unexpected results, it's for the parallel port control register.
Thanks
Sputnik :idea:
This should work:
if byte and xxx then
xxx can be any bit position like 1 2 4 8 16 for a single bit ...
best regards
I was just about to delete my topic as I have just figured it out, this is how I did it:
CLS
INPUT "Enter port address: ", port
byte = INP(port)
value = 128
FOR i = 0 TO 7
LOCATE (11 - (i + 1)), 1: PRINT i
LOCATE 1, 1: PRINT "Bit | Place Value | Bit Value"
LOCATE i + 3, 10: PRINT value
IF byte >= value THEN
bit(i) = 1
byte = byte - value
ELSEIF byte < value THEN
bit(i) = 0
END IF
LOCATE i + 3, 24: PRINT bit(i)
value = value / 2
NEXT i
I know it's probably messy and could be more efficient but, if it works, leave it.
But thanks anyway,
Sputnik :idea:
