Yukta2007
Junior Member level 3
Hello
I have been working on a simulation implementation of ring oscillator based TRNG(True Random Number Generator)
Can someone help me with the test bench of the code and if possible, explain the code.
It would be of immense help
Thank you.
The code is as follows
Thank you.
module ringosc (clkout);
output clkout;
parameter NUMGATES = 3;
(* keep="true" *)
wire [NUMGATES-1:0] patch;
generate
genvar i;
for (i = 0; i < NUMGATES-1; i = i + 1)
begin: for_gates
(* keep="true" *)
assign patch[i+1] = ~patch;
end
endgenerate
(* keep="true" *)
assign patch[0] = ~patch[NUMGATES-1];
// Plain output
assign clkout = patch[0];
endmodule
module trng_wrapper (clk, resetn, random_num);
input clk;
input resetn;
output reg [127:0] random_num;
parameter NUMRO_TRNG = 10;
wire random_bit;
wire [NUMRO_TRNG-1:0] ind_ro_output;
always @ (posedge clk or negedge resetn)
if (!resetn)
random_num <= 128'h0;
else
random_num <= {random_num[126:0], random_bit};
generate
genvar i;
for (i = 0; i < NUMRO_TRNG; i = i + 1)
begin: Ring_Osc
ringosc RO (ind_ro_output);
end
endgenerate
assign random_bit = ^ind_ro_output;
endmodule
