BojackHorseman
Newbie level 6
I want to simulate the code for a seven segment display but I am not getting how to write the test bench for the same. I generate the test bench using ISE Xilinx but when I simulate by giving input values SEG and AN are shown XXXXXX(in red) in the simulation waveform.
Can someone help me in writing the test bench for the code or give me some hints as to how to write a test bench for this code.
[moderator action: added CODE tags]
module sseg(
input clk_100MHz, // Nexys 3 clock
input [3:0] ones, // ones value of the input number
input [3:0] tens, // tens value of the input number
input [3:0] hundreds, // hundreds value of the input nnumber
input [3:0] thousands ,// thousands value of the input number
output reg [6:0] SEG, // 7 Segments of Displays
output reg [3:0] AN // 4 Anodes Display
// Parameters for segment patterns
parameter ZERO = 7'b000_0001; // 0
parameter ONE = 7'b100_1111; // 1
parameter TWO = 7'b001_0010; // 2
parameter THREE = 7'b000_0110; // 3
parameter FOUR = 7'b100_1100; // 4
parameter FIVE = 7'b010_0100; // 5
parameter SIX = 7'b010_0000; // 6
parameter SEVEN = 7'b000_1111; // 7
parameter EIGHT = 7'b000_0000; // 8
parameter NINE = 7'b000_0100; // 9
// To select each digit in turn
reg [1:0] anode_select;
reg [16:0] anode_timer;
// Logic for controlling digit select and digit timer
always @(posedge clk_100MHz) begin // 1ms x 4 displays = 4ms refresh period
if(anode_timer == 99_999) begin // The period of 100MHz clock is 10ns (1/100,000,000 seconds)
anode_timer <= 0; // 10ns x 100,000 = 1ms
anode_select <= anode_select + 1;
end
else
anode_timer <= anode_timer + 1;
end
// Logic for driving the 4 bit anode output based on digit select
always @(anode_select) begin
case(anode_select)
2'b00 : AN = 4'b1110; // Turn on ones digit
2'b01 : AN = 4'b1101; // Turn on tens digit
2'b10 : AN = 4'b1011; // Turn on hundreds digit
2'b11 : AN = 4'b0111; // Turn on thousands digit
endcase
end
always @*
case(anode_select)
2'b00 : begin
case(ones)
4'b0000 : SEG = ZERO;
4'b0001 : SEG = ONE;
4'b0010 : SEG = TWO;
4'b0011 : SEG = THREE;
4'b0100 : SEG = FOUR;
4'b0101 : SEG = FIVE;
4'b0110 : SEG = SIX;
4'b0111 : SEG = SEVEN;
4'b1000 : SEG = EIGHT;
4'b1001 : SEG = NINE;
endcase
end
2'b01 : begin
case(tens)
endcase
end
2'b10 : begin
case(hundreds)
endcase
end
2'b11 : begin
case(thousands)
endcase
end
endcase
endmodule
